If you're running raids for loot rather than ego fights, the Snap Hook is one of those tools you'll feel missing the moment you don't bring it. Ermal's weekly stock won't always be packed with dream rewards, but this item changes how you move through a map. It helps you climb, cut across awkward routes, escape bad angles, and reach extraction with less drama. That matters just as much as chasing ARC Raiders BluePrints when you're trying to build long-term progress without throwing away half your backpack every other run.
Why the Snap Hook deserves your ARC Parts
A lot of players look at trader rotations and immediately scan for weapons. Fair enough. Guns are exciting. Still, mobility wins more raids than people admit. The Snap Hook lets you take paths other Raiders ignore, especially vertical routes above busy streets and open choke points. You can loot faster, leave danger sooner, and reposition when an ARC unit or hostile squad pins you down. It's also easier to justify the purchase because it can be kept in your Safe Pocket, which takes some of the sting out of failed extractions. If Ermal has it, it should sit near the top of your shopping list.
How to prepare before visiting Ermal
Getting the Snap Hook isn't complicated, but you do need the right resources. Focus your runs around ARC components, rare parts, and high-value zones instead of wandering from container to container with no plan. Hit tougher enemy patrols if your gear can handle it. Check resource-heavy areas, then leave before the whole lobby collapses onto the same loot trail. Once you've got enough materials, open the Nomadic Envoys menu, check Ermal's stock, and trade for the Snap Hook before the rotation resets. Don't wait until the last night if you can help it. That's when mistakes usually happen.
Building around PvE instead of PvP
The Snap Hook gets even better when your skill build supports long raids. PvE isn't about winning every duel. Most of the time, it's about reaching more loot, carrying it out, and not burning all your stamina before extraction. Start with Mobility skills like Youthful Lungs and Marathon Runner, because stamina affects everything you do. Running, climbing, backing out of fights, crossing open ground. After that, push into Survival for Security Breach. That skill is huge for loot-focused players, since special containers can hold strong weapons, rare materials, explosives, and valuable blueprints. Broad Shoulders, Looter's Luck, and Looter's Instinct then make each run feel less cramped and less wasteful.
What to buy after the mobility tools
Once you've secured the Snap Hook, your spending should stay practical. Weapon blueprints are still worth chasing, especially if they unlock reliable loadouts for later raids. Raider Tokens can help with account progress, while consumables should be bought only when you actually need them. Cosmetics are fine, but they don't get you home alive. In the skill tree, Conditioning comes next for heavier kits, with Loaded Arms and Used to the Weight helping you move better while carrying stronger weapons and shields. If you're planning your upgrades carefully, checking cheap ARC Raiders BluePrints can also help you compare what's worth prioritising before you spend hard-earned parts on short-term rewards.
U4GM Arc Raiders Ermal Shop Best Purchase Priority
